Walchit
- Joined
- Aug 29, 2021
- Posts
- 447
- Reaction score
- 910
The guy in that video modified the pickup tube so he could put the bolt back in the other hole. I'm probably just gonna pull the whole thing out and see how bad it is. It's probably f#@$&d anyway, might as well get it out of thereThe oil pump is harder plus you pretty much have to pull the pan to do it. You need to remove the balancer, front cover and timing chain. I mean, there’s supposedly a cheat where you loosen the front of the pan and let it hang down a bit and then stuff a rag in so you can’t drop the bolt into it but I have heard getting the pickup tube bolts in is almost impossible. I wouldn’t try replacing the pump with the pan on myself.
