Truck leans to one side
Yeah I figured that message would fix it I just can’t pinpoint why all of a sudden the driver side would go up not down so basically if I level it out I’m going to take away the drop aspect of the truck I’m baffled at why the Driver side would raise up front and back
That’s a good question. Have you put it on jack stands and inspected everything to see if something looks out of place like a spring not in its pocket? Maybe try that and if nothing looks wrong drop it down with the floor jack fast on the driver side to see if it settles. I can jack one side of mine at a time by finding the balance point on the frame to jack from, then if I drop the jack fast it settles good. Just a thought.
TollKeeper
Brighton, CO
I personally would start by jacking up the rear of the truck, with the jack under the pumpkin of the diff. After both wheels are in the air, look to see if they are equally spaced at the gap of the wheel to the wheel well. If both sides are about equal. Than you know the problem is in the front. If they arent equal, its in the rear.
Edit: This will at least get you started. Its possible its in the front and back.
02escalade
02escalade
New jersey
I’m try jacking it up this weekend amd take some measurements and really look around ..Besides the wobble I’ve been driving the truck almost a 1000 miles a week for work
02escalade
02escalade
New jersey
it’s the weirdest thing the driver side raised up ….. Passenger side is the height it’s supposed to be after it was lowered
02escalade
02escalade
New jersey
Well pretty tied up this weekend but took a quick measurement the driver side is sitting close to 3 inches higher
02escalade
02escalade
New jersey
So now I’m so confused maybe it is leaning to the passenger side But that’s a huge difference Does anybody know how I can find the stock height of an 02 Escalade 2 Wheel Dr ? Just curious because then I can deduct the drop spindles and keys to see what the lower height would be
02escalade
02escalade
New jersey
02escalade
02escalade
New jersey
Do those springs look normal ?? Look really compressed but they are eibach lowering springs I’ve been working crazy hours so I haven’t really been able to look but my buddy asked me to take a few pictures for him
2DoeProjectHoe
