Just Fishing
I also forgot to share this, these are the brushes i used to clean out my new pushrods.
Mine has that noise when the oil is fully warmed. Longer pushrod is the solution for me I think.Last night i did some thinking about some valvetrain noise i hear under light load at around 3200-4000 rpm.
It's been bugging me a bit since it seems to be getting louder.
Maybe i need longer push rods, lifter is being difficult/faulty, or maybe I need to ensure i fully torqued them down all the way.
The sound reminds me of my old S10, if you get the throttle cable routed incorrectly, it can pulsate some engine noise right down the cable into the passenger compartment.
but there are no cables that could do that in the tahoe...
Other option is the hard line i used for the catch can.
but i have that setup with rubber flex joints, and lined with the same stuff anywhere it makes contact with anything hard.
Mostly to prevent wear, but it should also sound deaden.
Then i remembered something, the 1.8 rockers.
I did some reliving of the valve cover to prevent this issue.
It's possible that in this area of rpm, i have enough oil pressure that the rockers are moving up more and hitting the valve cover.
I did some driving around last night to repro the sound, and with the windows down.
It's louder outside the truck than i thought, but it's still hard to hear unless i'm driving against a wall or another car.
If they are even slightly coming up and hitting the valve cover, then there is my issue.
So my task later today, pull the valve cover on the driver side.
if I see signs of contact, more reliving.
and I'll probably do the same to the passenger side if it's found.
from there, I'll probably bite the bullet and order some spacers and the updated valve cover.
I'm crossing my fingers that this is the issue, but i doubt I'm that lucky.
Hope you have a wideband coming in the mail so you can finish tuning it properly before you blow it up
