Just Fishing
i compared one of my new H3 mounts to the mounts i took off of my hoe, and they look identical except for the heatshield.
it's smaller on the H3 mounts.
I assume that's because the fluid filled original mounts needed more heat shielding, so they gave it a larger air gap.
Also when you go to remove the mounts.
The bottom nuts are captured.
just onbolt from the top.
I was all trying to hold the top and unbolt from the bottom...
