Highlighted posts from Monday, Apr. 12, 2021
TYFBot
Click here to view on the web
Highlighted posts
April 10, 2021 * 23 posts * 318 views
87carl said: Went to change oil few minutes ago and found this on the drain plug alot of flake and a couple big chunks. She has been throwing p0016 cam crank code for couple of weeks. Could ... Read more >>
April 09, 2021 * 25 posts * 518 views
the_tool_man said: +1 for BB tune. They can do a lot more than the Range device. I had them turn off AFM, firm up the transmission shifts, and turn off the downstream O2 sensors for future exhaust ... Read more >>
April 11, 2021 * 11 posts * 140 views
randyg said: I have a 2011 4x4 Yukon SLT, 5.3L, 6 Spd, 3.42 Rear Axle, 2 Spd Transfer case, with HD Tow Package (oil cooler, HD trans cooler, increased fans/radiator, trailer brake controller) ... Read more >>
April 11, 2021 * 13 posts * 168 views
01Burb713 said: Recently put some 2013 GMC Sierra Denali 20' wheels on my burb. I think it looks like a whole different ride. Found them used for $200 bucks with 6/32 tire tread on them already. ... Read more >>
April 09, 2021 * 18 posts * 351 views
Wylie_Tahoe said: Currently have an 03 4wd with 5.3 flex and looking to upgrade by a few years and lower miles. So my question is, starting in what year, did the Tahoe offer a larger engine? And ... Read more >>
April 08, 2021 * 16 posts * 275 views
mnjeepmale said: I just took delivery of a 2011 Tahoe LTZ. It has the Bose sound system and I want to replace the radio with an aftermarket DVD radio and have Andriod Auto and keep the rear DVD ... Read more >>
April 08, 2021 * 25 posts * 522 views
09_4WD_YUKON said: Honestly, if you are wanting a suspension lift, I would stay away from Rough Country and go with a BDS lift. I had a BDS lift on my '04 Z-71 and can attest that is a top notch ... Read more >>
April 11, 2021 * 10 posts * 87 views
Shtiv said: Hi guys, for frm home and has better light came on, and alternator voltage gauge dropped to 11. At Oreillys, they say everything looks good. But can't start car as if battery is ... Read more >>
April 09, 2021 * 15 posts * 194 views
RichardCranium said: Long story short, I had a thread from 2018 for a retrofit that I had adjustment issues with.....so I parted it out and went LED. Since that info was no longer relevant, I wanted ... Read more >>
April 09, 2021 * 7 posts * 174 views
VAguy68 said: Hi all. 2021 Z71 and I'm experiencing weird noises on certain occassions above my head (headliner area). It comes and goes but it seems to happen after a rain and when I'm driving ... Read more >>
Continue reading...
mont
