treehan77
TYF Fiend
Crestview, FL
B414B328-0798-4C4F-A8D3-DF497A798673.jpeg Need help with a part # or name for this small hose that comes off a port on the passenger valve cover to intake- it is splitting and hard. 5842F9BA-C530-42E5-9F78-396FF7413250.jpeg
NoReverseYukon
NE Wisconsin
Got the new valve body and wiring harness back into the 4L60E. Went to take her for a test drive to get the trans temp up to check for P1870 code/symptoms. Test drive didn't last long - noticed rotational noise coming from both front wheels that increased with speed and turning. My first thought was wheel bearings, but I replaced those less than 500 miles back.
Question - can bad front axles give the same symptoms as wheel bearings ? It's not the brakes, the sound doesn't stop when applying them.
If I decide to replace them, what is the best brand to go with ?
Thanks.
rs401
