donjetman
- Joined
- Oct 22, 2018
- Posts
- 1,363
- Reaction score
- 2,360
Is there an improved valve cover I should be looking at, instead of just changing the gasket? If so, what's the item #? Thank you
The pvc setup in the original valve cover clogs up. This prevent the pvc system from keeping a vacuum on the crank case. Instead you end up with pressure in the crank case which forces oil out of the engine via gaskets, piston rings, etc.
The new improved driverside valve cover, GM# 12570427, is the fix.
