cfmistry
Ok fellas I need some help. I was wiring my radar detector into the rearview mirror harness and I must have shorted something. Now I’m not getting power to that lead which shows the temp/compass (though OnStar still works), AND the foglight icon on the dash doesn’t light up green (but the fogs and switch work fine). I checked the regular fuses and didn’t see anything blown. Any ideas??
89Suburban
Bull in the china shop
SE PA
You go through the drive thru with the boat in tow?
**** yeah, big guy stuff.
You check the fuse panel on the side of the dash too?
89Suburban
SE PA
@89Suburban
The OEM tight fitting Oil Filler Tube PN: 609729947
I don't see any listings for it unless you want used, but being it's a one time use...
Doing some searching you might be able to find some new old stock somewhere.
(grabbed it hoping it said "710" on it for lols with the wife, nope!)
:D
Just ordered the used one, see how it goes.
16yukon
