Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
I have an 06 Yukon with a 3” & 2” leveling kit. I’m running 33” tires on it. I want to upgrade my brakes and I am looking at hawk and power stop. Anybody have any opinions?
Had Powerstop drilled and slotted Rotors with their carbon fiber/ceramic pads on my Camry. Stopped great. Rotor runout was within spec (within 2/1000’s). I have Hawk pads with OEM rotors on my Yukon. Stops great!
I think you’ll be happy with either company (although I’ve never tried Hawk rotors).
I am assuming you have hydro boost brake system and whatever you use and the system is working properly, you will have great stopping power. If you had vacuum brake system then I would want as much rotor surface and carbon fiber pads as I can get. I had an 02 LT and now have a 2005 Z71 with hydro boost. The difference is up top for sure.
Do the nnbs front rotor and caliper upgrade with good pads and you will have a great performing brake system for a few hundred bucks. The rear MB’s brakes are better than the nnbs so just keep those and upgrade pads and/or rotors.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
