Back from the dead 2007 Tahoe 2wd LT
Other then the french fries, find anything good? It's always like a treasure hunt when you take apart a used vehicle.
Leevon
Leevon
LOL not this time. They were for sure Braum's fries though! Final count was a bunch of lost fast food receipts, several pens, some small toys, a battery and probably $5 in change but it was so nasty I sucked it all up and dumped it. There were some dryer sheets that had been caught up under the driver's seat, I guess that was a substitute for actually cleaning.
I once found the full wallet and checkbook from the previous owner jammed behind the glove box in a truck. The guy was really happy to have it back, thought it had been stolen.
LOL not this time. Final count was a bunch of lost fast food receipts, several pens, some small toys, a battery and probably $5 in change but it was so nasty I sucked it all up and dumped it. There were some dryer sheets that had been caught up under the driver's seat, I guess that was a substitute for actually cleaning.
Nice. Always nice to do a good deed.
Leevon
Leevon
So I'm at $1,471 for parts to date, not including supplies or tools, but I am further along than I anticipated for the money. Not having to do ball joints, tires, etc. has been good for the budget. I still have to address the fuel tank leak, hopefully that's a cracked fitting or a line and not the pump then I am planning to take care of the rear main seal, oil pan gasket, oil pressure sending unit, and valve cover gaskets. After that, with a few more "test" miles it should be ready for driver status then finish the exterior cosmetic stuff at an easier pace. Not bad progress for 6 days I think (bought last Saturday). Here's the current parts list.
  • Aftermarket Dual cigarette lighter bezel 362151493233
  • Aftermarket Front grill bowtie 224205201390
  • BOSCH Wiper blade 4922
  • Dorman Inside door handle 81181
  • Fel-pro Valve cover gasket set vs50504r1
  • GM Brake pedal pad 15706042
  • GM Headlamp Assembly - Left 2502263 (GM389-B101L)
  • GM Headlamp Assembly - Right 2503263 (GM389-B101R)
  • GM Oil pan gasket 12612350
  • GM Steering wheel assembly 25849482
  • OEM Console lid (used)
  • OEM Door Handles - Bermuda Blue (take-offs)
  • OEM Driver's seat belt buckle assembly 19121537
  • Sachs Lift support sg330072
  • Sachs Lift support SG330073
  • Seat Shop Durofoam Seat Bottom cc-14-foam-d Seat Shop
  • SKP Rear main bearing seal/plate/bolt set SK635518
  • SMP Low beam headlight socket/pigtail s553
  • Steering wheel / airbag emblem bowtie 163656384137
  • Ultra-power Intake manifold gasket MS96587
  • Valeo Rear wiper blade
  • ACDelco GM Original Equipment Fuel Tank Cap GT295 Fuel Tank Cap
  • ACDelco GM Original Equipment Spark Plug R44LTSM Spark Plug
  • ACDelco Professional Spark Plug Wire Set 9748RR Spark Plug Wire Set
  • Anchor Doan Engine Mount 3211 Engine Mount
  • Fel-Pro Engine Oil Cooler Gasket 72435 Engine Oil Cooler Gasket
  • GM Genuine Parts Vapor Canister Vent Solenoid Harness 19257603 Vapor Canister Vent Solenoid Harness\
  • GM Genuine Parts Vapor Canister Vent Valve 23481275 Vapor Canister Vent Valve
  • GM sensor, airbag front end discriminating 15854647 left front impact sensor
  • GM Shield, engine 22781371
  • MicroGard - MANN+HUMMEL Filtration Technology Air Filter MGA42487 Air Filter
  • OEM Pipe, transmission fluid cooler lower 22802047
  • OEM Pipe, transmission fluid cooler upper 25999417
  • Autel TPMS Sensor x 2
Leevon
Leevon
The durofoam seat bottom is in, and I made some repairs on the seat back. It felt a little soft because the wings were split where it wraps the seat frame. So I glued the foam together, cut some canvas drop cloth an stuffed it back in the cover. It feels like new.
thumbnail_IMG_5350.jpg thumbnail_IMG_5327.jpg thumbnail_IMG_5344.jpg thumbnail_IMG_5347.jpg thumbnail_IMG_5349.jpg
firstcaddy
