AFM disabler?
BG1988
is there any AFM disabler that works correctly with the hybrid? i.e CVT mode works
at lest with CVT mode i would still be able to get decent mpg 20-21 range only doing about 18-19 with M4 (v8 only 4 speed) i know this is soo much better then what the 5.3/6.2 guys get even though it's 6.0L
B
BG1988
Do those Range units that plug into the OBD port work on hybrids?
it has a different ECU then the "normal" at some point i'll have a "full hardware disable".(when i save enough money) :)
B
BG1988
i looked on the website it says it does
but i'm not sure if it also disables Eco Mode or 6th gear which would get me 20-21 in the city
4 speed gets 17-19 in the city( well 17 if i hit every single red light ) 19 if i get every single green light...
St. Louis
I wouldn't think it would disable any gears, especially an overdrive gear
Cbrpilot2
