2006 gmc yukon xl slt option 2 electrical
Woodblocker55
Here's what does I use remote start and goes in to reduce engine speed and the throttle doesn't work at all. So I shut it off with remote sequence to shut it off. Retighten battery post normally about 1/16th of a turn and restart all is good for another 3-5 months . Seems to when it's more humidity in the air like bit of fog . Anyone have any idea ? I'm in minnesota so it's lives in cold .and what this hanging off the negative cable ? e974c478471520a0e7b95ae7690b9f74.jpg
Sent from my LGL722DL using Tapatalk
Matthew Jeschke
Sahuarita, Arizona
Is that controller 15263889 some sort of new fangled alternator controller?
It almost appears GM changed alternator system to only run when needed? I could be wrong, I just googled the part number on the side.
I would start with obvious if you have not already... Check grounds on motor, motppl r to chassis, alternator, etc.
I would also check to see what connection looks like on that controller. Clean it up if need be.
Sent from my SM-A505U using Tapatalk
Woodblocker55
Woodblocker55
those read regulated voltage and fail.
Are those boxes a problem child ??? I cleaned ground under driver's door . And hood ground.
I will look in to what else I can clean up .
Woodblocker55
Woodblocker55
I don't have to unhook the battery to unhook and clean that plug do I ? It won't mess anything up will it ? It's HD charging 160 amp
Matthew Jeschke
Sahuarita, Arizona
I am not sure. I typically unhook the battery just to be safe.
Fiest place to check though is grounds when you have intermittent electrical (or control) problem.
Scottydoggs
NJ
ive yet to look close enough to my own to see if they come off, but most cars its part of the neg cable.
Woodblocker55
Woodblocker55
Yes mines just zip tied but there's loop around ground cable. So it have to slide off a end.
Or is deal where you just change the guts ?
There not much room around mine ..pictures miss leading I slid cellphone down between to bunch junk to get this picture . Computer all junks right in that corner .
that's the rvc sensor (regulated voltage control) and that would not be your throttle body problem, that sensor is not serviceable if it is in question just replace it or get a new ground cable it will come with a new sensor.
Woodblocker55
Woodblocker55
So your saying it's the module on the throttle body right .. Why when I retighten battery posts. It's good for another 3 months ..If I don't retighten battery cables . I just keep getting the reduce engine speed on the dic ..
Is that how the throttle body acts when it's going out ?
I think one I need to order doesn't come with a cable . Thats if that's a problem.
Can I just install the throttle module ..does it program it's self ?
I ordered a throttle module.. throttle body.
Is this the codes it throws ?
Cbrpilot2
