It bugs me that 35’s don’t fit...
HUMOROUS1
SC
2005 tahoe, with level kit. Keys are just about maxed out. 33" fury country hunter m/t x 12.50 x 24's
24x10 Positive 24 offset no rubbing
Wanted 35" m/t but would've had to trim
F
Fifty
Can someone post what needs to be trimmed for 35’s on a level with zero offset vs Oem offset?
I know on most vehicles, the Oem (having offset) bs requires less trimming.
I think the 18 inch oem wheels are 8 wide so that can run a skinny 35 no problem and even a 12.5 wide if needed.
F
Fifty
I messaged them. Who knows. Maybe they will respond.
It’s crazy that this community doesn’t have a trim list for wheels/tires and lifts.
even the Colorado community kind of has that and it’s a group that has burned so many manufacturers and vendors that it’s almost a dead platform.
gat0r
DFW
guessing notmany are rushing to put 35's on. shrug
i lowered mine
if i lifted it, id probably stick w/ 33's or 34's
STORMIN08
i think the point that most are missing is this...
for practicality of the intended use, most will not run a 35" tire on these vehicles, there are lifts that accommodate such size.
to run a tire of that size with little to no lift is not how the vehicle was engineered, CAN a person get a 35" tire on with massaging or trimming, probably so, but will it perform as it should...highly unlikely.
just driving down the road using a 3-4" travel aspect, the tire will probably roll, but try to USE the vehicle and all things go south rather quickly.
the newer generation mall crawler would love to have 20" w x 40" t tire on a lowered truck...just doesnt work
Willis12345
