Replace passenger HID bulb?
ReaperHWK
I bought 6000k D3s bulbs as well as 6000k led for the high beams and fogs.
I just replaced the driver side HID but the passenger side looks like I have to remove a bunch of crap to get to it. The owners manual is no help. It gives directions for the driver side but for the passenger side It literally says “see dealer”.
Does anyone know what I need to remove to get access? Looks like maybe just the air box but wanted to know if anyone had some tips before I start ripping things apart.
hcvone
Huntingdon Valley, PA - Town of Webb, NY
When I did my bulbs on my 19' tahoe, I had to remove the Callaway air box, behind that is a bracket and access panel that has to be removed, no big deal, once you remove the air box it will all make sense, driver side was about 5 minutes to remove the HID lowbeam and highbeam and replace with new HID and VLED led higbeams, the passenger side maybe 10-15 minutes
PG01
Up here to the right
Pull the bumper cover and then headlight...Much easier than trying to get you hand in there from behind.
ReaperHWK
ReaperHWK
Thanks. I'll do the airbox removal first. I was able to get my hand in there to do the driver so I think it won't be a problem once I get access. It took some time to figure out the right angle to get in there but I know what I'm doing now (I think..)
PG01
It’s definitely doable from inside but annoying to me. I can have the cover off my ‘13 hoe in about 5 min, little longer on the ‘19 yuk but still so much easier imo. To each their own tho. Good way to give everything a good look over both ways tho.
ReaperHWK
ReaperHWK
Good to know for "Plan B" or if I needed to replace the headlight housings that it's not that hard to remove. Some cars are a PITA.
DefiantOne
