Rare As "Cluck" 1999 Military 2 door Tahoe For Sale !!!
bayareadude84
Methahoma(temporary)
Truck is in Georgia
Doesn't get more rare than this folks !!
I read on Wikipedia those were for export only to foreign militaries ??
1999 2 door Tahoe C2500?? HD built for military spec
Export only !!! Look at those clear rear windows and It has 6 lug HD wheels !!!
Hope someone here can save it ??
VIN # Compnine info below. Ya im a nerd
https://www.govdeals.com/index.cfm?fa=Main.Item&itemid=6&acctid=12050
UM7 RADIO,AM/FM STEREO,ETR,INCLUDES CLOCK STEREO W/CLK(UM7) 2,711
UQ5 SPEAKER SYSTEM,4,DUAL FRONT DOOR MOUNTED,DUAL EXTENDED RANGE QUARTER MOUNTED 4 SPKR SYS(UQ5) 3,105
VPH VEHICLE PREPARATION OVERSEAS DELIVERY VEH PREP OVERSEAS DELIVERY(VPH) 1,293
VR6 HOOK,TIE DOWN TIE DOWN HOOK(VR6) 1,262
VXS VEHICLE - COMPLETE 21,664
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73) 20,446
XBN TIRE FRONT LT245/75R16/C BL R/PE ST TBL OOR (9591410) TIRE(XBN) 644
X88 MARKET BRAND CHEVROLET CHEVROLET(X88)(EXPORT) 21,664
YBN TIRE REAR LT245/75R16/C BL R/PE ST TBL OOR (9591410) TIRE(YBN) 644
YD3 AXLE FRONT (BASE EQUIP) FOR SCHEDULING GVW PLATE FRT AXLE(YD3) 21,664
YD6 SPRING,REAR(BASE EQUIPMENT) RR SPRING(YD6) 21,664
YK6 IDENTIFICATION - (SEO) 1,158
ZBN TIRE SPARE LT245/75R16/C BL R/PE ST TBL OOR (9591410) SPARE TIRE(ZBN) 644
ZE5 IDENTIFICATION - TRIM LEVEL BASE 135
ZW9 BASE BODY OR CHASSIS BASE BODY/CHAS(ZW9) 10,888
01U EXTERIOR COLOR,PRIMARY,SPECIAL OVERRIDE (01U) 93
1SA PACKAGE-OPTION 01 (1SA) 3,053
13I INTERIOR TRIM,LT SMOKE GRAY (13I) 14,656
13V TRIM COMBINATION VINYL, LT GRAY (13V) 1,306
5Z5 HUB CAP---DELETE 5Z5) 23
6GC SPRING COMPTR SELECT FRT LH SUSP(6GC) 13,511
7GC SPRING COMPTR SELECT FRT RH SUSP(7GC) 13,511
8E3 BUMPER,REAR,PAINTED,BLACK PAINTED RR BPR(8E3) 26
8E8 FRONT PAINTED BUMPER PAINTED FRT BPR(8E8) 26
8F2 ORNAMENTATION DELETE & SHIP LOOSE EXTERIOR DELETE ORNAMENTATION & SHIP LOOSE EXTERIOR(8F2) 26
8T7 SHAFT FRONT WHEEL DRIVE WITH PROTECTIVE COVER SHAFT,FRT WHL DR(8T7) 51
9V5 COLOR COMBINATION,WOODLAND GREEN (9V5) 93
AM7 SEAT,REAR FOLDING RR FLDG ST(AM7) 21,661
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3) 21,664
AXP VIN IDENT POSITION, MULTI- PURPOSE VEHICLE MULTI-PURPOSE VEHICLE VIN POSITION(AXP) 21,661
A50 SEAT,FRONT BUCKET FRT BKT ST(A50) 2,553
BAG PARTS PKG EXPORT PARTS PKG(BAG) 1,293
C5P Unknown 17,342
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60) 21,645
DE2 MIRROR,OUTSIDE,LH & RH,DIRECT CONTROL,FOLDING,PAINTED O/S MIR(DE2) 3,000
EVA TEST DVT, EVAP EMISSION REQUIREMENT EVAP EMISSIONS REQUIRED(EVA) 20,347
EXP EXPORT - I.E.S. EXPORT I.E.S. EXPORT-SPECIFIC MARKET AREA EQUIPMENT(EXP) 1,293
FE9 FEDERAL EMISSION CERTIFICATION FED EMIS(FE9) 15,180
FK2 ARM,TORSION BAR,SPRING ADJUST,LH TORS BAR SPR ADJ ARM(FK2) 4,594
FK3 ARM,TORSION BAR,SPRING ADJUST,RH TORS BAR SPR ADJ ARM(FK3) 4,594
GT4 AXLE,REAR,3.73 RATIO 3.73R(GT4) 9,258
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80) 16,547
JB5 BRAKE SYSTEM,VACUUM POWER DISC,DRUM VACUUM PWR BRK SYS(JB5) 20,426
KNP COOLING SYSTEM,TRANSMISSION,HEAVY DUTY HVY DUTY TRANS CLG SYS(KNP) 18,155
K47 AIR CLEANER HIGH CAPACITY HI CAPACITY A/CL(K47) 7,910
K60 GENERATOR,100 AMPERE 100 AMP(K60) 18,444
L31 ENGINE,GAS,8 CYL,5.7L,CPI 5.7R(L31) 20,426
MSL PLANT CODE SILAO, MEXICO, GM DE MEXICO SILAO,MEXICO PLANT(MSL) 21,664
M30 TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC 4-SPD A/TRANS(M30) 20,426
NA1 EMISSION SYSTEM,LESS THAN 8500 LB GVW EMIS SYS(UNDER 8500 LB GVW)(NA1) 20,426
NF2 EMISSION SYSTEM,FEDERAL,TIER 1 FED EMIS SYS(NF2) 18,966
NY1 SHIELD,FUEL TANK F/TANK SHLD(NY1) 12,437
NZZ PACKAGE,OFF ROAD SKID PLATE,SPORT SKID PLT PKG(NZZ) 12,437
QBN TIRE ALL LT245/75R16/C BW R/PE ST TBL OOR TIRE(QBN) 644
R7K CONTROL - SALES ITEM NO. 36 1,851
R9Q CONTROL - SALES ITEM NO. 91 76
SLL SOLD ORDERS SOLD ORDER(SLL) 6,611
Guitarded
Edmonton, AB
I've always wondered why the interiors on these military trucks look as bad as they do. They seem to always be just destroyed.
Still, would love to get my hands on this one. Importing to Canada could be interesting.
Lol “woodland green”. What’s the towing setup on it? Not a normal receiver.
79jasper
Pintle hitch.
You've never been around the military, have you? Lol
Sent from my SM-N960U using Tapatalk
Multnomah Falls
Yea, pintle hitch. The tow bar on whatever they hook up to is a steel round circle that sets inside that pintle. Very hard to break anything with that set up. Very heavy duty.
navyboy14094
