Z55 suspension question
you said in your first post: I had the shop look over the suspension and they said everything was fine
ivin74
05 NBS Nali
Htown, Texas
Z55 suspension does get old. As the strut/shock wears out, the computer sees this and applies more current to the struts/shocks to maintain what it thinks the ride should be. It basically locks itself up on every bump. When I replaced mine and reset the ALC, it drives extremely smooth and responsive. I also have Eibach front and rear sway bars, Z55 is awesome when it's all working.
@mikeyss
How did you reset the ALC? I have a tech 2 and cannot figure it out
@mikeyss
it's in there I think under "body" vehicle needs to be unloaded and parked sitting level, I just ran the tech2 cable out the drivers window
I think all it does is basically let all the air out of the shocks and waits a second to take a reading at 0 psi. to get a calibration.
it will say in there somewhere "reset trim" probably under special functions.
takes like 30 seconds and it's done.
ivin74
05 NBS Nali
Htown, Texas
It's under the chassis part, then special functions.
Going to try it this week, thanks guys
ivin74
05 NBS Nali
Htown, Texas
@Doubeleive
I don't get that option on my Tech 2, I tried the body and chassis and can't find anything about the suspension.
PascalBlues
