2008 Navigation GPS cuts in and out
Western NC
Hello all,
I have 2008 Yukon SLT with navigation. The problem I have is the GPS cuts in and out. I can just be driving along and I will have a red line through the GPS symbol and it will show me off the side of the road and then just cut back in and start working again.
I also need to probably upgrade the firmware. How does one come up with a disc for this?
Last thing, my XM radio doesn't work. It will say searching for channels and never finds them.
Any help is appreciated, Thanks
PG01
Up here to the right
Hello all,
Sounds like loose connections on back of head unit... gps and xm antenna plug in there.
Hello all,
Jeff, you may have a bad coax cable, antenna and or the GPS antenna. The navigation disc was last updated in 2016 and I keep pestering GM and Here! but so far no luck. Get a Tech-2 or bi-directional scan on your truck and look at the internal body module codes which will tell you where the problem lies.
Jeffrey Howell
Western NC
I think the GPS antenna is somewhere in the dash if i'm not too far off. I am going to pull the head unit and check the connections, Ill look at the antenna then. If not, Tech 2 it is. Thank you
Yes, the one GPS antenna is just under the top of the dash, the other is integrated with the shark fin.
Here's where it is at 17:47 or so in this how to video:
DefiantOne
