Show off your 2015-2020 lowered tahoes and yukons
Low07Hoe
Looking to add some bigger sway bars to my 2016 Yukon lowered 3/6. If has to much body roll to keep going how it is. Curious to what everyone is using and your review of them. Thanks.
gat0r
DFW
hotchkis & hellwig have the largest bars avail ([38mm]1.5"/ [32mm]1.25").
its amazing how well my burb handles. i thoroughly enjoy spirited driving in the corners
CMoore711
Which one's do you have? Hotchkis or Hellwig?
I was close to pulling the trigger on the Hotchkis kit a week ago, but no one has them in stock and all part sites say they're special order. So I reached out to Hotchkis directly to check their lead time and they informed me they wouldn't start shipping the 2292 kits until late August. Not too bad I suppose, I've had car parts sitting in my garage for far longer than a month awaiting install.
gat0r
DFW
the kit i got was rebranded. i am pretty sure its hellwig., based on front bar design.
also pretty sure it was the only one on the market when i got my burb. others came out shortly after
Staggered 02
I went with Hotchkis sway bars front and back for the Escalade. Have Hotchkis on pretty much all of my rides except the Duramax. Went with a Hellwig set up on the Duramax once I confirmed that Hotchkis didn't make a set for the Duramax. You will like the suspension response without a doubt.
adcs2k
San Antonio
My ‘15 Escalade 3.5/4” front and around 5” in rear. Rear mag Delete. Front upgraded Beltech sway bar. About to eliminate front Mag also. 24” Dub wheels with 295’s. Magnaflow muffler and a dual black tip added. Also added a Texas speed cam, AFM delete and a tune. Runs absolutely amazing.
