What the hell is this?
Multnomah Falls
Does anyone know what this thing is? I was moving my passenger front seat all the way forward and heard the metal on metal sound of this rubbing and reached under from the back and found this. It does not go on the seat, I am assuming. I think it is from elsewhere and found it's way to that place.
RST Dana
OH
Multnomah Falls
Ok, I was thinking it may well be something from back there in the jack area but never saw anything like that when I did remove the jack once because of a flat tire on the road. I guess it has been under that seat the whole time I have owned it. I bet it is a PITA to reinstall. Really looking forward to messing with it tomorrow. Thanks for the heads up.
Scottydoggs
NJ
it actually holds the tools in the bag, not the jack the three bars and the lug wrench. the jack gets turned till its tight in the mount that part gets screwed to a hook that hooks the body of the jack then holds the two wheel chocks and you clip the bag in that part then screw that part on the end of the hook.
RST Dana
OH
“Hooks the body of the jack” Can you get your jack out without removing this piece? You can’t on mine.
Have a pic of that whole deal? I pulled mine out once and I just threw that sucker back in there.
Scottydoggs
NJ
just checked my manual. it holds the tools to the outside wall in that hole. the hook has its own wing nut to hold the chocks to the jack body.
Franny
