FU's 5.3 to L9H 6.2 thread
FrankU
Babylon New York
I posted in a thread about wanting to change the cam etc on my DOD 5.3. By the time I got done with everything (parts gaskets time etc) finding a L9H 6.2 was a no brainer for me. So I waited and found a good deal on a L9H with verified miles. Yesterday we fired the L9H up with the 5.3 BB tune. Glad I made the decision to do the swap. I'm going to wait till I find a good VVT cam etc to get the retune done at BB. Texas speed has been out of 8620 cam blanks and I'm also hearing some negative responses about they're cams , but that's from internet cowboys.Can anyone post up about experience with mild VVT camshaft on a L9H both good and bad ? Thanks
AND it begins !!
Foggy
KS
I'll be watching this as I want to do a non DOD cam in my 14, but retain
the VVT for milage/drivability.
I looked at the Gwatney performance website, but no real info on their cams
mikeyss
Longmont, Colorado.
I just ordered a TSP VVT cam for my L9H with the normal core since the 8620 core was out of stock. It's going to be at least a month until I install it though, I'm waiting on ARH Headers and some other small parts.
Foggy
KS
What are the specs that you ordered on your cam???
Foggy
KS
thanks.. that would be too big for me.. you will need a good tune
R3cord303
Posse In Effect
Oregon Valley
I did Texas Speed's Low lift Stage 2 cam in my 07 and freaking love it. I'm sure they have something like it for the 09+ engines with VVT. its 212/218 @ 550 lift. Funny enough that before doing that cam and the 2" Rough Country leveling spacers, my combined average MPG didn't change at all. I did have a custom dyno tune done, though I need it to be re done now that there's more miles on it.
Time slips yet?
FrankU
FrankU
Babylon New York
Brand: COMP Cams
Manufacturer's Part Number: 156-401-13
Part Type: Camshafts
Product Line: COMP Cams XFI SPR GM Gen IV VVT Camshafts
Summit Racing Part Number: CCA-156-401-13
UPC: 036584197560
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 1,600-6,700
Intake Duration at 050 inch Lift: 214
Exhaust Duration at 050 inch Lift: 228
Duration at 050 inch Lift: 214 int./228 exh.
Advertised Intake Duration: 267
Advertised Exhaust Duration: 281
Advertised Duration: 267 int./281 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.559 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.571 in.
Valve Lift with Factory Rocker Arm Ratio: 0.559 int./0.571 exh.
Lobe Separation (degrees): 114
Camshaft Gear Attachment: 1-bolt
Computer-Controlled Compatible: Yes
** This is one of the camshafts I'm considering
mldawson11
