Weird cluster/gauge issue. Help!
chilleblanco36
Weird thing happened Wednesday morning in my 2010 Tahoe. Started it up and only gauge working was the voltage gauge. Tpms was blank, oil pressure was 0, fuel was flat, and neither speedometer or tach was working. I drove a few miles to see if it would pop back on. It didn’t.
I stopped and turned the truck on and off a few times, then everything went back to normal. Now it’s working fine the last few times I’ve driven it today. What’s the deal with that?
It’s been fine since then.
kbuskill
NE. FL.
I would check/clean all your grounds under the hood.
It also may be time to replace your battery cables as they tend to corrode internally and cause.these types of issues as well as others.
chilleblanco36
chilleblanco36
Will do. So far this haven’t happened again, but I do know it didn’t fix itself
Juju14
