Has anyone pieced together their own lift kit?
BrownSunshine
I’m looking at 3.5-4” of lift. Most kits don’t have exactly what I want so I was wondering about putting my own kit together. So far this is what I had in mind.
Bilstein Adj Height fronts (either 5100 or 6112)
Rough Country 2” leveling kit
Freedom Off Road Control Arms
Some type of differential drop kit
Bilstein 5100 rear with shock extender
Suspension Max 2” rear Coil spacer
Rear sway bar extensions
I want to replace the shocks anyways because the factory ones ride like crap. I hate how bouncy the Tahoe rides.
My wife doesn’t know for sure how high she wants it lifted. We have decided on 20x9’s with a 0 offset and 305/55r20 Ridge Grapplers. I figured with the adjustable fronts I could start at 3” and go up to 3.5-4” depending on how high she wants it.
Anyone done anything similar like this?
olyelr
Elk Rapids, MI
Why not just get the BDS 4” Fox coilover setup? Im not familiar with their coilover setup, but maybe it is possible you can lower it down so it isnt quite 4”.
With that much lift you will need some type of diff drop... Im not sure you can just purchase that separately.
SlimJim
did you ever figure this out?
mitchievu
