PG01
Up here to the right
Awesome. I’m officially pissed at GM. After tearing the entire dash out of my truck to replace my ac evaporator temp sensor to fix dtc b3933 I found out from a TSB that I don’t have such a sensor in my truck, the replacement HVAC head unit I installed last month needs to be programmed via TISWeb and my Tech2 or that dtc shows up and the ac won’t work. No wonder I can’t find that sensor. :mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad:
Sorry mark, see post above.....:)
At least you were able to finally figure it out.
5strmtrp
Not a pit thing. My jack Russell Porkchop does that when its really hot out. Our Heeler does it too. Zeus the collie does not. But hes old.
Also. My bad. Turned this into show your dog's. Haha
Sent from my SM-N950U using Tapatalk
Kee Fuller
las vegas
This is exactly how I do it. I watch for it to start sputtering, shut it off, add more fluid, start it back up and repeat. Usually takes about a full wasted gallon before what's coming out looks identical to what's going in.
Here's the first video I Googled. This Hotel WiFi is kinda slow, so I just skimmed through it. Not totally sure of the content/relevance:
Yall use power steering fluid or atf?
Kee Fuller
las vegas
aaah this is how I had my crash course in how the rear hvac works in the yukon xl, after I tore it all apart and tested this and tested that and found a very much non-existent wiring diagram to discover my truck does not have said "sensor" and the rear ac wouldn't work, same issue controller needed to be programmed to my vin
in the process I spent hours on it and replaced a $125 actuator that was fine
patrickleeleep
