Sunroof Dead
Kpwweb
My sunroof died as well—in the open position. But I didn’t have a windshield replacement or anything like that. Turns out fuse 8DL had blown, which is unusual since nothing has been added to any circuit.
If someone else has the same problem, be sure to check not only the sunroof fuse in the right fuse box (30A), but also the 10A fuse for the switch in the left fuse box.
Hope this helps someone.
Matthew Jeschke
Sahuarita, Arizona
15163056 is the acdelco part number
i would assume most all in junkyard have same problem. more of gm's famous plastic gears.
wonder if perhaps somebody sells the gears?48fa620c4c9e9433eec64c004db7a99f.jpgd544f34281c9615d8823af835edd9618.jpg8bab2aa6501423bbf3e4944b309361cd.jpg
Sent from my SM-A505U using Tapatalk
I may have to call back junkyard and see if there are anymore sunroofs.
I wouldn't assume just because a car is in the junkyard that the sunroof motor's are all bad, it is the most common failure but some people never even open the sunroof so plenty of good motors out there.
the motor should be the same for denali, escalade, or any with a sunroof
