Randeez 2012 Budget Yukon Denali Build (stick on hood scoops galore)
randeez
randeez
south florida
Yeah, hitting overdrive would be ******* the transmission, we always held it to 3rd. With 4.10s @ 125 MPH you're motor's turning about 5400-5500 rpms. Up to 130 would be around 5700 mathematically. Is that what you're seeing?
yea except with converter slip unlocked, which is about another 700rpm
Onebad1983
Resident Country Dumbass
Well, you can go back to 3.42s or 3.73s, turbos don't like to pull on a lot of gear or raise the RPMs! Did you build it to spin to 7,000 rpms? How about the transmissions and transfer case?
If he had a 6.0 or 5.3 he could spin 7k rpm all day on SBE lmao
yup, just trying to push the absurdness of 1k hp reliably. itll get turned up as needed with "supporting mods" lol which is now bigger injectors and turbo
Alright then, hammer down! So should we do another get together in a 2-3 weeks? Do you want to run her at Orlando or keep her close to home while you're getting dialed in?
randeez
randeez
south florida
i'll prob fix the fuel pressure, tune, and see if it'll actually break into 10s cause that'll be essentially free at this point. turbo did drop pressure a little bit maybe a psi or 2, over each gear shift to red line. was only making about 12-13psi after each shift not sure if theres much left in this "little guy"
i think track messed me up... usually all the racegas, tire smoke, methanol, etc gives me a little head ache in the morning (im getting old? lol) just acts like a hang over but was rough all weekend. they had a lot of meth cars out there that were testing for crap going on all weekend.
Sam Harris
Texas
And is there some reason we haven’t seen the video evidence of said track day...? [emoji35][emoji2959][emoji1787][emoji106][emoji631]
Sam Harris
Texas
yes, cause if it blew apart i wanted to make sure there was no evidence :deal:
[emoji1787] but we wait for this for weeks.. months.. then nothing..? What a tease to see this beautiful engine build, transmission, t-case, and all those lovely supporting mods, and a track day with no evidence.. [emoji35][emoji853][emoji22][emoji3525]
randeez
randeez
south florida
Lol, give it a few days theres a guy that films at all the test n tunes he should have it in there. Only did two runs
Phoenix2k9
