Trouble code P1682
Multnomah Falls
no the tune is loaded thru the obd port with a hand held programmer, it wouldn't have anything to do with the ignition circuit problem
I knew it was done thru the OBD port but I thought maybe other places like the fuse box was involved as well. Live and learn. I preach basics all the time so I recommended rechecking the previous work just done and forgot about checking the battery. That is as basic as it gets. :confused:
I knew it was done thru the OBD port but I thought maybe other places like the fuse box was involved as well. Live ad learn. I preach basics all the time so I recommended rechecking the previous work just done and forgot about checking the battery. That is as basic as it gets. :confused:
when you load a canned tune the device just plugs into the obd port, then you turn the key to run, load the tune, turn the key off, done!
Z
Ziggyboy
Sir, your input is well appreciated!
Thank you again, and thank you for your service!
Sent from my SM-G960U using Tapatalk
Sowegatahoe87
