03 Yukon slt awd with 4 low
Multnomah Falls
While I did run shops many moons ago I am still learning that the Yukons and Tahoes have so many differences in their options and I am still getting used to that.
Ou812
Ou812
PENNSYLVANIA
Well, it would be the AWD type without the central disconnect. The difference between a 4x4 and AWD front differential is in the right side axle tube and shaft. The center sections are the same.
If I was to order axle seals I wound need to go off of the rpo code?
Juju14
