Show off your 2015+ leveled Tahoes and Yukons!
mikeb3408
Debating on whether to install suspension max 1.5” level or tough country 2”.
will my front still be slightly lower with the 1.5” and completely level with 2”?
olyelr
Elk Rapids, MI
Yea, pretty much. If you want it perfectly level by measurement (will look slightly nose high at times) your gonna want the 2”. If you want it to “look” level and not nose high, then get the 1.5”.
I am curious why you would switch companies for the 2”?
mikeb3408
Thanks, sorry my installer initially quoted me the 2” rough country, and I didn’t realize they had a 1.5”.
Any preference on which brand to go with?
HiHoeSilver
Away!
Chicago
Price difference? What does each kit entail? Spacers, shock extenders? Springs?
BlackYukon
I'm kind of a Retard
Be sure to Take some measurements of your own vehicle before pulling the trigger on a leveling kit. I have a 2" Level on mine and it's about half an inch low from being perfectly level, but a buddy installed the same Level on his ride and it's about half an inch higher than the rear, so every vehicle is going to be a little bit different.
2010georgiacrew
Trying to decide between 275/70R18 and 285/65R18 KO2s. Feel like either setup rubs or doesn’t rub deciding on who you ask. If it were my truck I wouldn’t mind, but the Suburban is our vacation mobile and needs to be as reliable and sensible as possible.
@Tiki What did you decide to go with?
Just got the wife a z71 Tahoe and can’t decide which tire size to go with the 2.5” motofab level.
Banjomatic
