Bose speaker replacement
Geoffsfas10
St. Louis
I had the infinity kappas in my old Sierra that had the bose, they are a 2ohm speaker. They sounded great with an aftermarket headunit, super loud and clear. When I put the stock headunit back in for various reasons ( when first one was stolen, when i traded in truck ) they sounded even better with the factory one. Sounded just as good as my aftermarket with a 10" sub. I know infinity isnt the most expensive or probably even the best anymore but I certainly liked them
kbuskill
NE. FL.
I have been lurking here for a while, and searched through tons of posts, but haven't found anything definitive.
Does anyone have a recommended speaker to replace the door speakers. 2013 yukon denali. They are blown. I have an aftermarket h/u but don't really want to get an amp, and rewire all the speakers and all that.
BUT I believe the bose speakers are an uncommon impedance, and replacing them with aftermarket while still using the bose amp system will cause issues.
Thanks in advance for any recommendations.
Here is some good info I posted about the Bose speakers ...
https://www.tahoeyukonforum.com/threads/bose-speakers.101909/page-5#post-1228439
Hope that helps.
I also went with Infinity speakers with the Bose amp and Kenwood HU it sounds great. I also have a down firing box between the 2nd row buckets. 12" Kicker Comp pushed by a Hi Fonics Brutus 600w mono block.
nsticka
I had to pull the rear door panel off to replace the door handle and the rear speaker was listed as 3.8 ohms. I have 12 denali.
I wanted to replace speakers but with everything I read, speakers are fine its the amp and sub that needs upgraded.
any suggestions on amp? I want a little more clarity and a touch more bass.
I am thinking of replacing center dash speaker and the speakers in A pillar as well.
J
jay-rod427
awesome @Joseph Garcia is gonna send me his old stockers. hopefully that will suffice and help fight off the urge to spend a bunch of money and replace the whole system with aftermarket.
holzl88
