2019 Tahoe..Pad and rotor part numbers for Brembo brake upgrade
louieb
I have been searching far and wide and haven't been able to find the part numbers for the Brembo pads and rotors on my 2019 Tahoe.
I don't need them replaced yet but it is a little concerning that I can't find anything online and I called a couple of dealerships and they don't have the part numbers in their system.
Multnomah Falls
Looks like the Tahoe is too new because they only show for 2018 or older. Have you contacted Brembo with your question?
L
louieb
By application i found the performance pads.
GM#84263246 $342 services both front
Year 2016-2020
Ah, you beat me to it. I finally got the numbers as well.
The above listed part have been confirmed to be the pads.
GM#84263238 are the rotors. $250 per rotor
hcvone
Huntingdon Valley, PA - Town of Webb, NY
Brembo off my 2019 Callaway Tahoe
Rotors #84263238
Caliper RH #23505026
Caliper LH #23505025
pads were with the calipers
If you replace them you will need to paint or powdercoat the rears to match the front, OR you can order Powerstop rear calipers already powdercoated red, I was lucky enough to get a set of Powerstop red rear calipers given to me.
Mistehkins
