DaRosa218
The Dude abides
Modesto, California
Yessir! Hope that takes care of it!
Same, I just bought my Dad's commuter off of him so I'm going to take my time going through the Yukon and repair issues as found. Along with the updated valve cover, I'm going to replace the passenger side valve cover gasket and intake manifold gaskets. I'll also check/replace the valley pan gasket and clean the intake including the throttle body.
So in the meantime it looks like i'm looking forwards to 43mpg? LOL
Wow!
Can you put one of your extra tree rivets in a drill and spin it while holding it up against a file to turn it down to the same diameter of the insert? Would that look any better?
That the inserts aren’t blind is a surprising discovery to say the least.
Nice idea and I might could do that if the cap spun evenly enough. They're just molded plastic tree rivets so they're not precision formed pieces and would likely wobble, resulting in an oblong head or an off-center turning at best. But, that'd just be a way to cap off the hole and the raised insert piece would still be very visible. I could screw in some set screws with thread sealer and top them off with silicone to accomplish the same thing.
What I was aiming for was to have a slightly domed, low-profile cap with a minimal edge to smoothly cover each one. Not an abrupt cylinder standing above the surface.
If I knew how the sheet metal around the insert would react, I'd drill off the raised portion and have what I want but better. The bumps on the roof covering the holes would be just the thickness of the tree rivet head and that'd be really clean. I'm pretty much at a standstill until I can figure out how to buff out those footprints.
That sucks. I don’t understand why GM went to that system of fastening the racks on the NNBS. It’s the first I’ve heard of it actually. I would be tempted to get an Esky rack and PTM and just leave the cross rails off. That would look cleaner to me than those huge rivnuts sticking up plus that would provide better protection against leaking since there’s gaskets involved.
My thoughts as well. Or, get a strip of low-profile body molding, hollow out where the rivnuts would protrude, PTM and stick that on.
I just don't get how everyone was saying they were blind holes. Just like measuring my spindle and then strut drops, I guess I'm the only that actually tests these things to have hard data.
Nice idea and I might could do that if the cap spun evenly enough. They're just molded plastic tree rivets so their not precision formed pieces and would likely wobble, resulting in an oblong head or an off-center turning at best. But, that'd just be way to cap off the hole and the raised insert piece would still be very visible. I could screw in some set screws with thread sealer and top them off with silicone to accomplish the same thing.
I used Meguiars Fine Cut Cleaner on a buffer to get rid of mine.
I don’t know about the NNBS, only the NBS but Im sure if anyone pulled a rack off a NNBS and didn’t plug the holes, hard data would have filled their truck with water. I know mine are blind.
wjburken
Eastern Iowa
Can you get to the bottom side of that panel? Maybe you could grind off or use pliers to collapse the bottom flange of the insert and pull it out without messing with the painted side.
Mickey_7106
Bay Area
True duals and h pipe will get you there
Thank you! I will eventually figure out how to tune it so that it crackles and pops on deceleration. I think all I have to do is copy/paste the dfco settings from a G8 tune file. That said I can’t figure out where my laptop is. It WAS in the laptop bag in my back seat but it is no longer there. Hopefully it turns up- because if not then some fool walked off with it
