kiwi
Mother Яussia
Did my second scheduled maintenance.
Oil change, new cabin filter (15k km and it was very dirty, decided to change it myself every 5-7k km), some winter preparations - cleaning/oiling power steps, rear ammo cleaning, greasing for locks and all rubber seals.
Dealer did not find the 4wd service reason again :( said they do not see any errors at all..
kiwi
Mother Яussia
My ride showed 4wd service notification and tried to switch to 4wd lo while i was driving in 2wd mode. OFC i didn't even touch the knob.
As for the transmission fluid change, campaign is not active here yet.
Besides i don't think its fluid issue, i assume my TCM module is buggy.
BlackYukon
I'm kind of a Retard
Wrapped the new esky mirrors since I didnt do blinkers...3f101d191c618630d1caabebca00be52.jpgac836b22c9b4f5b5a9bd710f00139c48.jpg
Sent from my SM-G975U using Tapatalk
Did you disassemble the mirrors to wrap the blinkers? I got my Esky mirrors in yesterday and want to wrap the blinkers before I install them.
K2 Kaiju
The Depths
Nope. I have a 4" roll left over from doing the the door trim. Cut it in half and just a little longer than the length (including around inside where mirror is). Peel, stick, and trim with razor. I got a cheap install kit off amz for like $10 when I did the doors. A heat gun is useful for setting the wrap in curves. Im new to the wrapping bit, but its pretty straight forward and simple; if you mess up, just peel it off and grab another piece...
Sent from my SM-T580 using Tapatalk
firedog9518
