Staggered 02
Escalade components sanded, prep work continues. All parts should be ready for install on my next trip back to Fl.
I asked the painter to hold off on the paint work since I just sent him a few other parts for my other truck that need to get painted. Might as well paint everything in one shot.
Making progress.
LT1ZOB
Making progress.
View attachment 234678 View attachment 234679
nice, what yr Escalade?
akbrener
Baltimore, MD
Matched my Hikari low beams with their high beam LEDs. PITA to get to the high beam dust caps, but all in all not a long project.
LT1ZOB
do the Hikari low beams allow you to use your factory dust caps? If so, can you post the part numbers/ or link for the low beams? I’m assuming I need a conversion kit?
cmatt
Left my hippo at shop to change halogen lenses to Koito bi-led lenses.
I don't personally trust aftermarket led lamps in halogen sockets, so full retrofit is a proper way to go.
Should dramatically improve my lows and add second highs.
Also will swap hb3 to hir1 lamps in highs and install 1500lm led backlights
Nice. I did HIR bulbs in my high beams as well. I’ve been gathering parts to do a bi-xenon retrofit with a clear STi lens.
The halogen projector lenses aren’t clear.
The factory HID projectors have fresnel lenses.
akbrener
Baltimore, MD
Lows: https://www.amazon.com/gp/product/B07GKPR452/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
Highs: https://www.amazon.com/gp/product/B07GKC818Q/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Fit perfectly under the dust caps. has about a 4" pigtail to tuck into the housing. Plug and play! Pay attention to the " +/- " stamped on the connector, it can go either way. + is the white wire on the wiring harness. Also, the actual "unit" is adjustable, so make sure that the 3 prongs click into place as designed and the LEDs are in positioned correctly. wiring off the fan should be at 6 o'clock.
There may be more expensive or brighter bulbs out there but the lows are plenty bright and honestly anything is better than the halogens. The fans are not noisy, can barely hear them with the truck off.
16yukon
