Denali Difference - Changes by Year?
MaineLife
Is there a resource or post somewhere laying out the changes or fixes by year?
Specifically I'd like to know what they fixed or changed between the Denali 15 and 16, thanks in advance!
CMoore711
Agree with above.
Any 2015 Denali with a 6 speed are early 2015’s. Any 2015 Denali with the 8 speed is considered a 2015.5 since the 8 speed was introduced mid 2015 model year. I’m not 100% but I believe the 2016 model year was the first production year they reduced the power train warranty from 5 year/100K down down to something less. Then in 2018 they change the front grille and added the 10 speed. There may be other MY changes others will chime in on but those are the major ones to the best of my knowledge.
GTNator
16 or 17 added HDMI ports for the rear entertainment system I believe.
91RS
GA
2015-16 had air conditioned seats. 2017 on has only "vented seats".
It's the same thing they just changed the wording because people were expecting actual air conditioned seats and not understanding the air inside the truck has to cool down before the air coming through the seat can cool down.
sealandsky
Minneapolis, MN
Yeah, not so sure about it being "the same". The design did change substantially between 16 and 17. My current 19 is the same as 17 and on. The ventilation is much less robust in the newer models and although at this point I can't be certain that there was no AC ducting to the seat it sure felt cooler, but maybe due to substantially less air volume.
2DoeProjectHoe
