Lighting Question
ARogg619
Hey guys,
I have a recently acquired 2000 Yukon SLT. if my lights are on, my brights logo Is on. THe brights aren't on though. If I click the switch and "turn off" the brights, my lights turn off. Any ideas why this is?
2010gmcyukon
Midwest
Did someone botch a 4-high mod? Can you tell if there is any splicing done in the spot where someone would do that?
Multnomah Falls
Yea, have you opened up to see the back of the headlights to see if someone used a wrong weird bulb or wiring has been hacked. Low beam is 9006 and high beam is 9005.
Wylie_Tahoe
Im guessing you've confirmed the low beams are not just burned out, and its the high beams that are actually on?
Headlight relay possibly. Check to be sure it’s seated in the fuse box, maybe swap it out with another and see if the problem follows the relay.
A
ARogg619
The lows are on, not the highs, im sure of that. But the dash says the brights are on anytime I have my lights on. 9006 is what is lit, I know that for a fact because I changed them to HIDs when I put the new housings in. I didn't see any butchered or patched wires when I was swapping in the new housings
Multnomah Falls
Now there is new info not talked about before. Was the problem there before or after you changed them to HID's? It would always help to know info like this in advance.
A
ARogg619
This issue is since day one of owning this truck ( about a month now ). Since changing the bulbs to HIDs and new housings, nothing has changed.
HiHoeSilver
Away!
Chicago
Hey guys,
Weird, for sure. Got some pics or a video in case one of us catches something obvious?
Phoenix2k9
