I/M Readiness WILL NOT set
just go get on the freeway and drive it for an hour @55 or as close you can get to 55, so drive one way for 30 minutes and then drive back the same way. If your plates just expired then generally you have 30 days to get them done if you get pulled over by some VERY slim chance, explain your situation and chances are good you will be allowed to continue without being ticketed. worse case scenario a fix it ticket.
T
Tahoe Z26
It’s the Evap system and Oxygen sensor heater that aren’t setting
BG1988
It’s the evap and the oxygen sensor heater
miles or km from last reset? is there any current codes or pending codes? or old codes? this may prevent from being ready..
or don't, the 02 should set if you do what I mentioned above, the evap might take a few tries you will have to drive it and then let it sit and completely cool down then drive it again and warm it up then let it sit and cool down again the evap only operates when the temp is below a specific threshhold @swathdiver I think has the specific temp noted, it has to pass it's self test X amount of times to set. you should be able to pass with one open anyway
afpj
The EVAP monitor is a pain in the ass. It requires fuel to be between 1/4 and 3/4 tank, engine cold below 80° (or so) and three cold starts.. I had to change a battery in the middle of a summer here in the high desert and it doesn't get below 80 (or so) until like a month ago so I went for three or four months without being able to reset that stupid evap monitor. Happens every few years when the battery dies in the summer.
rockola1971
Indiana (formerly IL)
Which ones aren't ready? In SHITCAGO, you only need a certain number and maybe 2 specific ones or something goofy like that. I have passed without readiness.
There, all fixed for you. Did you realize this emmission test crap is not all of Illinois? (most likely just chicago and maybe some its tree hugging suburbs). I was born and raised in central IL around Decatur area and there hasnt been any emmission testing since i was born....1971.
How you generally fix this is leave the ****** state/city you are in and move to FREEDOM. I am now in Indiana and FREEDOM is great!
158 degrees to run certain tests with scan tool is what I ran into. But then last time, we did them with the motors up to temp so I think other factors were at play as well.
HiHoeSilver
Away!
Chicago
Actually, it's not just Chicago. It's also down in East St Louis. It's a STATE law, that's imposed in certain areas to meet FEDERAL regulations. Don't get me wrong, Chicago politics make me barf. But let's at least use facts.
The Federal Clean Air Act (42 U.S.C. § 7511a) requires states to provide a plan to control air quality in any area that doesn't meet NAAQS standards for ozone IF their state as a whole doesn't meet FEDERAL air quality requirements. They can do that any number of ways. Vehicle emissions testing happens to be a fairly popular one nationwide (32 states). Some states, like Florida, meet the federal air requirements and don't HAVE to do anything, anywhere, if they don't want to. Others, like Massachusetts just blanket test statewide (ANY state, yes even Illinois :eek:, could do this if they wanted to).
The point is, it's ultimately a FEDERAL regulation that's being satisfied by state laws one way or another.
If enough people lived in Decatur, Illinois would have to come up with something to show Uncle Sam. Whether that be emmisions testing, requiring you to use an electric tractor, or limiting your herd. On the other hand, if Chicago didn't exist, IL would likely meet federal standards, and unicorns would fart rainbows over all the land.
For free, once every other year, I can manage to keep my CEL off. It's the "safety" inspection states that really have the racket going.
Juju14
