So happy, but check this mpg out
Rosson03
Kentucky
I have a 2007 GMC Denali 6.2 L
I know it's been talked about lots and lots of times on this post but I cannot be even begin to tell you how pleased I am I have AC Delco synthetic blend in the engine ACDelco synthetic in the transmission completely throughout mobile 1 synthetic and the front and rear differentials I have AC Delco synthetic in the transfer case, I have a K&N air filter. The excitement was too much
I did not reset my meter it raised on itself I will do the math on paper and follow up stay tuned if you like. Feel free to post your MPG
intheburbs
SE MI
No way, no how, did a change of fluids and an air filter increase your mileage by 20%.
Standard-issue Dex6 is already a synthetic blend, and if following the recommendations, you already had full synthetic in your rear axle. Your transfer case takes Dex6 as well, so that should have already been a sythetic blend.
And if your air filter is increasing your mileage, it's because it's less restrictive and filtering less, allowing larger particles of crap to be ingested into the engine.
Using your measuring stick, then using full synthetics would increase your mileage another 10-15%, right? Why stop at synthetic blends?
Rosson03
Rosson03
Kentucky
Well buddy that's all I have done honestly
Thanks for the heads up on the air filter
So about this Denali about a year ago only done simple oil changes and I got a Bonus at work so I was like you know what I'm going to change my fluids and it was bad. Probably nothing ever been changed on it!
Danny3737
That’s a sizable increase for just changing the oil. A few other factors can affect it as well like tire pressure and front end alignment just to name a couple. With the colder temps coming, it’s not uncommon to see a few pounds of air pressure lost for every 10 degree drop in temperature. The biggest of all when it comes to mileage is your right foot.
Multnomah Falls
I used to own a Silverado and it had the MPG counter on it and I found myself driving very differently to keep the MPG high as possible. I am so OCD it was a PITA!
Kind of like that insurance commercial where the lady keeps saying, "Don't mess with my discount".
TheAutumnWind
How many miles have you driven since you reset your mpg counter?
I'll bet it starts to go back closer to normal
Rosson03
Rosson03
Kentucky
I have not reset it I have done about 8 fill ups went Florida but after that 5 $25 pumps, and this last one I filled it up twice so I would say approximately 3500 to 3800 just a guess
Also if anybody wants to know I'm approaching moon shot the big 200k Miles
DefiantOne
