Need to soften Z71 suspension out of necessity
Titusville, FL
I currently own a 2006 Z71 4x4 Tahoe which I purcased used in 2011 wth 65K miles and Goodyear Wrangler Silent Armors 265 70R17s. Both my wife and I enjoyed the ride and on road handling. It was an improvement over my 1996 Ford Centurion Classic 150 (aftermarket conversion of a F-150 into a 4 door Bronco). In 2016 my wife suffered nerve damage in her lower back and though she still likes the truck the stiff suspension causes her pain when encountering road irregularities. Current tires are B F Goodrich AT KO2s 265 70R17s. I try to keep the tire pressures at between 32 and 34 psi. I still need the 4x4 option, not so much for off roading but for slimey boat ramps. I plan to go back to the Goodyear as BFG has never solved the age induced noise increase problem with their ATs. Would like to keep this truck as I am not a fan of the newer designed Tahoes with ther unsprung foam rubber seats.
I don't know if changing springs will help. I looked through some GM parts sites and noted that my year Tahoe had 5 different max spring loads - 2819, 4222, 4692, and two that are listed as discontinued 5228, and 5841. I'm also wondering if adjustable shocks would help. I run Koni adjustables on my 07 Mustang GT Convertible and they allow me to set the ride for road or track.
Any help will be appreciated
DanangMarine68
Titusville, FL
Anyone else have suggestions. As mentioned above, not a fan of newer model Tahoes due to seats and not a fan of anything with a transverse mounted front wheel drive engines.
You can change all the shocks and the front springs to the ZW7 standard (without G65). This will soften the ride. Your KO2s are woefully under inflated, you'll quickly wear them out at those pressures but I bet she rides like a marshmallow! Mine did anyway until I aired them up right to keep the wear down. Noise wise, no complaints.
1992rs
OR
Concentrate on shocks first for sure, but check to see which torsion bars you have. There should be a tag on it with 2 letters. GMFS has a page called torsion bar 401 and you can cross reference which bars you have and how they rank amongst stiffness. I know my Denali, and id bet most of the premium/loaded rigs, has the XK bars which is the softest of the group designed to be used with autoride I’m guessing. You might have stiffer ones depending what options you got. If you don’t mind the work, swapping them out could be beneficial.
Also keep in mind that a huge portion of ride quality comes from the rear. Just like torsion bars, swapping your rear springs to something softer in combination with the right shocks can transform the ride drastically, which is a lot easier to replace than torsion bars.
DanangMarine68
Titusville, FL
Actually got the tire pressures confused with my Mustang GT. Tires are at 40 PSI. Shocks are what came with the vehicle as far as I can tell, may take some contortions to read embossing on upper half. Torsion bars have the code JN 325 stamped into the front ends. There were remnants of paper tags on rear of torsion bars Left had LXL and right had RX? with the question mark looking like the bottom half of a R. If I remember correctly the shocks have more to do with the harshness of rebounding from a road imperfection. Sorry for the delay in responding. Family health issues have been taking up much of my time.
Currently getting the mouse fur on the headliner replaced, front seat base leather covers replaced as well as the carpet.
