2015 rims on a 1996?
96-2D-Hoe
Someone has a set of 2015 Tahoe 18" rims and 95% Michelin tires for only $400. It would cost me at least 2x that just for a set of tires that I will need very soon. I'm not crazy about them but they look decent. Better if I painted them black.
Currently have 17" rims and truck has been lifted 2" at the back and torsioned at the front.
I'm sure they will fit in the wheelwell but will the rims fit properly to my 96?
Edit. Found the same rims searching through previous posts and they fit.
Squirrelsmith
yes i was looking for those for my 98 2 door but found some 20" off my friends 2017 silverado. They also fit perfectly
96-2D-Hoe
96-2D-Hoe
I didn't grab them. But every couple days when I fill the slow leak in my rear tire I think of them. Thanks for the info.
Tiki
Wait and find some z71 18s
Big Mama
Virginia
Yeah....for $400 you maybe should have. You’d have plenty of time to save up for or find what you’re after and had a set for winter
96-2D-Hoe
96-2D-Hoe
Was thinking my truck would look a bit 'beefier' with a wider tire and the 18" rims would allow a 12" wide tire. There's loads of wheels and tiresfor sale on FB marketplace.
Big Mama
Virginia
Nice to have options good luck in your search and post pics when you’re done
96-2D-Hoe
96-2D-Hoe
My current rims are not 17, they are 16 with 285/75/16 tires.
I didn't think these would fit, but after looking at the current wheels in the well and the amount of space...
These are 35/ 12.5 and my current wheel is 32.8/11.2
Could they work?
DLM_GT
