Test Drive today
HiHoeSilver
Away!
Chicago
It's where you make one thread containing a compilation of everything you've done, as opposed to a scattering if steps that have to be read piece wise
Agreed.
sorry a novice to the forum thing.
It's ok, you're off to an awesome start with s swap right off the bat!
If you create a thread for your build in the "under construction" section, we can ask a really helpful moderator to combine your current threads into that one so all your progress is together.
1badc4
1badc4
Agreed.
Okay thanks. I will try to figure that out, some things were interior, some powertrain etc. I was concerned about keeping in correct section.
HiHoeSilver
Away!
Chicago
The "under construction" section is a little different in the fact that each thread is a single vehicle and it's "journey". Poke around in there goes a minute and you'll see what I mean. If you start a thread in there for your Tahoe, we should be able to combine things like your "big day coming", "1 in 1 out", "almost there", "test drive", etc. to chronicle your truck.
1badc4
1badc4
Thanks' thread had been started.
