Jet throttle body
kbuskill
NE. FL.
I'm not trying to stir the pot any more but if my memory serves me, I believe that @BlackBearPerf or @JennaBear stated one time that the factory TB was capable of handling something like 500hp before it became a restriction.
A larger TB will certainly give you more throttle response but that is not the same thing as more power.
thompsoj22
california native "REPUBLICAN" high desert
Snake oil....? Ok so you speak from experience. Have you had one installed on yours? Ok.so the answer is No. So how can you say it would not work? I hate people that make **** up just to be in a conversation. I asked, you don't know but your best speculation is no. Wow that's impressive. No I have not bought one yet. Just payed for a 42k trans cooler for my ppv. This will be next.
one to many sugar cookie's?
I've also read that.
Eod1
Eod1
If you see me running, I would try to keep up.
Phoenix Arizona
You know , fu$k , all I was looking for as the OP was something like.
1. Dont waste your time.
2. There are better ones out there.
3. I use this one ________
4. Never used it.
I never thought I would get a bunch of Henry "Smokey" Yunick's wanna be's . Just so I know who is here. The more 100 dollar Bill's you throw at your hoe the faster she is going to go. It's a old drag racers saying.
1. Dont want your time.
4. Never used it.
ya the ls3/ls7 one I mentioned is like $200 cheaper, oem and probably gets the same (almost nill) results, but I figured if it's good enough for a Corvette and Camaro it's good enough for the Denali
St. Louis
What are the different sizes of the throttle bodies?
What is the size of the Jet one?
What is the size of the LS3/LS7 one?
I know the stock 6.2l is 87mm, what is a stock 5.3l size? Will one from a 6.2 bolt on to a 5.3?
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
2001 Yukon SLT
the ls3/ls7 one is 90mm so your stock intake would fit pretty snug and may take some modification to the plastic intake assembly or the engine cover, I think the oem 5.3 ones are 85? could be wrong
tfi racing
Don't forget to buy a set of MSD or Accel coils and plug wires to really take advantage of that extra airflow...
4. Never used it.
You pretty much got #1 and #4 in the third reply, but it wasn't what you wanted to hear so you pitched a fit.
mitchievu
