GSDunk
- Joined
- Apr 23, 2017
- Posts
- 25
- Reaction score
- 15
I've been driving my 2003 SLT for about 2 years and aside from a couple if annoying electrical problems, the old girl has run beautifully.
The 5.3 has about 150K on it and is still as quiet and smooth as a V-8 can possibly be. Still purrs like a kitten and the synthetic oil is always golden and clean even after over 4500 miles on each oil change.
Couldn't be happier with the Vortec.
Great power, torque and overall smoothness and im sure most of you would agree that this is one awesome engine.
...... But today out of nowhere something happened.
I came to an intersection rolling to a red light at about 5-10 mph when the engine just turned off. The electrical system is still working, but now when I turn the ignition..... nothing.
The engine doesn't crank and doesn't make any effort to try to fire up.
I've checked most of the fuses and only visually checked for any bad connections or loose wires. I really am a greenhorn when it comes to computerized cars with fuel injection. (The carborated V-8s were a little less complicated. I could always get my 350 running in the '76 Blazer and the. 345 in the old Scout was even easier still.
So what I'm saying is....... I am absolutely clueless about what to do with the Yukon.
What are the most common symptoms for this problem? What are the vital things I need to check?
And since I couldn't find the voltage regulator, I figured I best get help from some of you brilliant GM wizards.
Thanx in advance
Thanx in advance
