Letter from GM on 2017 Denali
Blackcar
Got letter from GM today on my Denaili dealing with increased braking effort ,hard pedal,and or potentially increased stopping distance.Something about engine mounted mechanical vacum pump output. Also says not following recommended oil change intervals could contribute to condition.They extended warranty 6yr or 72,000 miles
Oil change intervals affect breaking? What do they recommend and what are YOUR intervals?
Blackcar
Blackcar
Doesn't recommend oil change intervals just what the owners service interval is which should be what DIC says
the vacuum pumps have been failing that is why they are extending the warranty (it is a known issue), I would imagine this is there way of skirting around a full recall.
I think something happens to a seal and then oil gets inside and that's why it takes increased braking pressure
What years and motors does this affect?
15+, Not sure if they changed anything on the late model trucks, like a different supplier or revision, etc it's been brought up the forum before. I think something happens to a seal and then oil gets inside and that's what causes the need for increased braking pressure
kylesimmons
