Do you guys have a way to delete 15+ magnetic ride
TheEngineer
Central, FL
Thanks for that Max, it's clear now what the current options are. The Bilstein 5100 cores would be interesting.
Is it possible to have 1-2" spacers with the Monroe full assembled struts on all 4 corners?
@G00se You could run a leveling kit in the front with the struts.
The rears are standard shocks and the ride height is (mostly) determined by the rear spring.
So you would need to buy a spacer for the two rear springs.
keegan
what were the part numbers for the Fox Shocks? I emailed them and their offroad department stated they aren't making anything for the denali?
keegan
Mine is a 2015 Yukon Denali. stock height, and plan on keeping it that way...
3rdGen
Not to beat a dead horse, but I figured out my temporary and long term fix for the magnaride delete issue. I have ordered the McGaughy's MCG3507 adjustable lift strut, uses the stock Coil and hat. Long Term I have ordered a set of custom adjustable King coilovers in black and chrome. Those wont be here for like 8wks so I will just eat the price of the McGaughys to get the wife back on the road safely.
Rajin Cajun
I ordered them today and order Fox coilovers for the front and the Fox 2.0 for the rear. Once everything is here and installed I'll let you know how it worked.
BHodge
Do you have part #’s for the fox shocks?
Adam10532
Finally got the Mag Ride deleted today. Thanks to Maxxed Performance in Baytown for installing the Fox coilovers W/ DSC adjusters and 2.0 rear shocks. The http://www.xineering.com dongles seem to be working like they should. We only got to put a few miles on it but the wife was happy. Better pics once i get it cleaned up.
Can you please post a picture of the bottom of the strut.
