Installing sub with stock Bose system
Volant1
Volant guy
Upland, CA
I just unscrewed the old one hooked up the power and ground and screwed the jl in
Mr45
Florida
Got any specs (size, dept and such) on the stock sub? I need a new one as well, and I'm not sure what will fit in the original location.
Volant1
Volant guy
Upland, CA
Next time I head over to my moms house ill grab it for you, Any 8" shallow sub will fit
MikeTheApeman
The armpit of America - New Joisey
the stock sub is a 6", no? Maybe a 5" (doubt it, but this is Bose, King of the Odd).
If you're looking for just enough bass to fill in what the door speaks can't do, I think JL makes a 6" sub. I don't know how low it goes or how hard it hits, but I would think that'd be the easiest sub to retrofit into the Bose box.
Note to clarify - I'm talking about the center console one in the newer hoes, not the cargo area one.
Mr45
Florida
Cool. I have a non-Bose equipped one though. But the side console looks the same as posted above, with the Sub and all.
DenaliRob83
Smyrna, TN.
So after reading these comments, am I understanding correctly, that there is no place in my Bose system to install a LOC without losing bass as I increase the volume unless I Replace the HU? :)
Thanks for the help
Woodblocker55
2006 Yukon XL Bose set up and I just want add another sub in stock hole in back that's now just a cover . There has to be a easy way to do it . Can't amp be under seat and run 12v to it and run just speaker wire to the back . Amps are pretty small now a days .
Sent from my LGL84VL using Tapatalk
Sam Harris
Texas
I’m planning on doing this as well. Unfortunately, not much time lately to get it done, but sometime down the road. I’ve got the swb Yukon, so was able to get a stock unit from an ‘02 Yukon for the rear location. You’ll have more room (and there are more stock boxes out there, if that’s what you want)
adriver
This is a 10 yr old thread, and your comments aren't even relevant to it.
22loweryak
