Biggest Tire with Level
OilfieldTrash78
I have a '16 Denali 4x4 with the stock 20" wheels. I plan to run your 2.5" front and 1"/1.5" rear leveling kit and would like to know the biggest tire I can run without any issues.
Thanks
jennifer_w
I have a 2017 suburban lt Z71 midnight edition. I have the black 18 in wheels. Swapping them out for a set of 20s. On stock ride height will 275/65/20 rub at all?
DenaliBQ
i wonder also with the bigger tires do you need to get the speedo re-calibrated ?
SuspensionMaxx
Larget tire I have had someone use is a 33/12.50/20. I suspect the 275/65/20 should clear. I have had a few customers use that size on the GMC Sierra Denali 1500 with our smx-gm725M leveling kit.
Alfonso Araiza
I have 2015 Yukon Denali planning on installing 275/65/20 with a 2.5" leveling kit anybody had this set up are there any rubbing?
Subanbur
I’m going for 275/70r18 with the 2.5 front lift and 1.5 rear
1denali5
Thanks
hey i have a 15 denali with 22's looking to level and go with a bigger tire without trimming i have no clue how big i can go
STORMIN08
i am acquiring parts as we speak...2.5/1.5...i plan to run a 285/55/22 as seen here, worst case, you may need to pull the inner fenders back some. there are numerous ways to accomplish this, i personally try to make them appear as stock as possible by reheating and shaping them87C8AB17-AB64-4131-ACED-0770B17F265F.jpeg
Powder Toast Man
I have the suspensionmaxx 2.0" in the front. Stock rear. 20x10 et-24 wheels 275/55r20 fallen at3w tires. NO rubbing, NO trimming.
2016 Yukon Denali XL mag ride with factory power steps.
Mistehkins
