Oil pressure problems! Am I screwed?
Jeffwiz87
Illinois
Hey everyone! I have an 2008 Denali with the 6.2 and I noticed recently the oil pressure seems low to me. It has 118k on it and is at about 17/18 hot at idle but driving I am at 40psi cruising at 80 at 2k. Start up cold it is between 40-60 psi. Replaced o ring on pickup,sender,new oil and filter. No leaks or noise. Any suggestions or ideas?
PG01
Up here to the right
Last oil change? little low on the hot idle but not terrible
Disregard i see now you just changed oil.
Any noises or codes?
J
Jeffwiz87
Illinois
No noises or codes at this time. I do drive this truck hard for sure. Only thing I did recently was rear main/new trans/new front diff/manifolds/injectors/etc. nothing directly related to oil pressure though.
Which filter did you use? I noticed that running Mobil One oil filter cost me a few psi compared to running a K&N.
Derick
Indy Suburbs
Sounds exactly like mine;
but everyone assures me its fine. Apparently chevy says operating is between 27-80 psi..sooo <shrug>
That being said, I want to install the high pressure, high flow oil pump. It's 150 bucks, but its a weekend job best I can tell.
Big Mama
Virginia
Sounds right my buddy the boat mechanic says my boats 350 only needs 5 psi to run. I know it’s a different set up just tossing it out there.
J
Jeffwiz87
Illinois
The filter I use is a pf48e AC Delco! Usually always run oe filters. And in dericks video that’s exactly where mine sits at idle. It used to be right at the 20 mark or a hair more.
SnowDrifter
Washington. The desert side not the Starbucks side
Pretty sure I'd shit myself, throw the wallet into the camp fire, cry through a box of tissues, then set my car on fire if I saw 5psi
PG01
Pf48e is the problem... isnt that the one with plastic innards or some shit?
kylesimmons
