Fosscore
- Joined
- Apr 16, 2014
- Posts
- 10,471
- Reaction score
- 18,073
Has to be a shallow mount 8". This is the OEM box below. Those original threads had some great speakers, but a lot have been discontinued. There was a Kicker one that was recommended. Maybe a newer edition would work. I have the box, just never have put a sub in it and missed that Kicker before it went out of production.
Hope this helps a bit more. I can get some tape measurements if you want to see? There might be some dimensions in this original threads as one of the guys did a pretty thorough job of looking at the box and all options.
OEM location.
Threaded bolts that go thru the inner body frame skin. Each bolt had one of the ears break off when pulling it back thru the square holes.
OEM location minus the sub box.
OEM location.
