Been a year now
kybob
Well, I joined this forum a little over a year ago. My 04 Yukon has been a good un., at least so far. It’s now got 142K , and during this past year I’ve only had to replace the 4WD position sensor.
My 3rd brake light has to be changed, but looking at the DIY videos, it doesn’t look bad.
Might upgrade the fog / aux lights. Stock are “ok” but would like a bit more light.
Great forum, and I read often even if I don’t post much.
BoB
Fosscore
Welcome.
Plenty to read for sure on all your topics above.
3rd brake light is a simple plug and play swap out with 2 screws.
There are some good change outs to LED fog light housings or just an LED bulb, but it doesn't really change the output other than whiter light.
Numerous options to go with. You can even use the OEM bracket in some cases and a pig tail from Amazon to plug into the OEM harness with a simple wiring connection to the new fog light housing.
Post up any questions in the NBS thread or ask a new one if you cannot find it in the search bar. :)
K
kybob
Thanks Fosscore. Just waiting on the weather to break.
DefiantOne
