Plimbob
The heat temp in my 07 Tahoe is fluctuating. I have it set at 84 and it will blow warm for 10 minutes then the air output will get cooler for a few minutes and then return to warmer. I re-calibrated the blend doors but didn't help much that I can tell.
I assume its a blend door motor issue but how do you tell which motor? I think there are three?
Any thoughts or experience with this would be greatly appreciated. Its getting pretty chilly are here and only going to get worse!
Thanks,
Tim
Thanks,
Tim
